OpenPLi 9.1 Backup for Vu+ Uno 4K SE Download & Flashing Guide
OpenPLi 9.1 Custom Backup for Vu+ Uno 4K SE: Features, Setup & Download Guide
This custom OpenPLi 9.1 Backup for the Vu+ Uno 4K SE delivers a fully configured, out-of-the-box Enigma2 system tailored for satellite, cable, and IPTV streaming. Built on the stable OpenPLi 9.1 Python 3 base, this backup comes pre-loaded with essential plugins, working CrossEPG integration, pre-configured softcam managers, and customized Full HD skins.
Key Highlights & Features
  • Pre-Configured Base Image: Built on stable OpenPLi 9.1 with updated kernel drivers for Vu+ Uno 4K SE hardware.
  • Working CrossEPG Integration: Fully configured CrossEPG importer for automated 7-day Electronic Program Guide (EPG) fetching.
  • Pre-Loaded Plugins & Utilities: Includes popular tools for IPTV playlist management, softcam setup, channel list maintenance, and system monitoring.
  • Custom Skins Included: Pre-installed Full HD and 4K interface skins for smooth menu navigation and visual picon/poster rendering.
  • Default Root Access: Pre-configured SSH/FTP login details for quick remote management via FileZilla, WinSCP, or Telnet.
Technical Specifications & Access Credentials
Target Receiver Vu+ Uno 4K SE (ARM Architecture)
Base Firmware OpenPLi 9.1 (Python 3)
FTP / SSH Username root
FTP / SSH Password vuplus
Default EPG Engine CrossEPG / EPGImport
Flashing File Format .zip (USB Flash Folder Structure)
USB Flashing Guide for Vu+ Uno 4K SE
1.Prepare USB Drive :
Prepares flash drive for bootloader recognition.
Format a USB flash drive (16GB or smaller recommended) to FAT32.
2.Download & Extract Image Archive :
Preserves required folder hierarchy.
Download the backup zip file and extract its contents directly to the root of your USB drive. Ensure the folder structure on the USB drive is:
USB:\vuplus\uno4kse\ containing the image files (rootfs.tar.bz2, initrd.bin, etc.).
3.Flash Image via USB :
Triggers firmware update procedure.
  1. Turn OFF the receiver using the rear power switch.
  2. Insert the USB drive into the front USB port behind the front flap.
  3. Power ON the receiver using the rear power switch.
  4. When the OLED screen displays "Press Power", press the front touch power button on the receiver to start flashing.
4.Reboot & Post-Flash Access :
Initializes updated environment.
Wait until the display indicates flashing is complete and the receiver reboots automatically. Remove the USB drive. You can now access the receiver via FTP/SSH using username root and password vuplus.
