XDREAMY Skin for Enigma2 Download & Setup Guide (OpenATV, EGAMI, OpenPLi)
XDREAMY Skin for Enigma2: Features, Setup & Download Guide
XDREAMY is a next-generation, highly customizable user interface skin created by Inspiron for Enigma2 Linux satellite receivers. Drawing aesthetic inspiration from the Dreamy and oDreamy skins, XDREAMY combines advanced rendering engine technologies—including the re-coded PosterX component by Lululla—with deep user personalization, allowing full control over layouts, color schemes, typography, and poster integration.
Key Features & Customization Options
  • Dedicated Customization Plugin: Built-in plugin to adjust all skin settings, color palettes, fonts, and screen layouts directly from the receiver GUI.
  • 5+ Layout Styles: Multiple main menu and InfoBar layout styles to choose from.
  • 15+ GUI Color Themes: Extensive color selection for menus, borders, highlights, and text elements.
  • 15+ Font & 6+ Key Styles: Easily change system typography and button key visual appearances.
  • 11+ Channel List Layouts: Diverse bouquet selection templates available with or without movie poster scrapers.
  • TMDB & OMDB Private API Integration: Add personal API keys to dramatically speed up movie poster and event metadata downloads.
  • Integrated Weather Setup: Direct configuration and installation for oaWeather and MSNWeather from the image feed with custom city search.
  • High-Performance PosterX Engine: Powered by Lululla's recoded PosterX component for fluid poster rendering without system lag.
Supported Images & OE Distributions
Image Distribution Supported Versions
EGAMI 10.x
OpenATV 6.x & 7.x
OpenSPA 8.x
PurE2 6.x & 7.x
OE-Alliance Builds OpenPLi, OpenViX, OpenBH, OpenDROID
What's New in This Release (Changelog)
  • Recoded Setup Plugin: Fully rebuilt setup interface with a new About section detailing skin specifications and supported images.
  • Direct Weather Configuration: Easily install oaWeather or MSNWeather from feed and configure local city locations directly inside the plugin.
  • Private API Keys: Added TMDB and OMDB user API key input fields to optimize event posters and VOD metadata fetching.
  • Enhanced Progress & Signal Bars: Replaced color gradient renderers on OpenPLi & OpenViX with high-definition gradient images for smoother SNR, AGC, and time-elapsed progress bar displays.
  • UI & Template Enhancements: Adjusted main menu templates across all image distributions for better readability and added numerous screen previews.
  • OpenPLi Fixes: Fixed screen saving functions, section headers, and preview renders under OpenPLi firmware.
  • Virtual Keyboard Progress: Initial implementation of an integrated virtual keyboard (work in progress across select images).
Special thanks to Lululla (code revisions, debugging, and PosterX improvements), giopet (testing and bug reporting), and oktus (design ideas).
Step-by-Step Installation Guide
1.Upload Package to /tmp/ :
  • Transfers IPK installer to receiver memory.
  • Transfer the enigma2-plugin-skins-xdreamy_all.ipk file to the /tmp/ folder on your receiver using FTP (FileZilla or WinSCP).
2.Install Package via Terminal :
  • Executes skin installer script via SSH terminal.
  • Connect via SSH or Telnet (PuTTY) and execute the installation command:
3.Activate Skin & Restart GUI :
  • Applies new graphical skin interface.
  • Go to Menu > Setup > Usage & GUI > Skin Setup, select XDREAMY, press OK, and confirm the GUI restart prompt.
4.Configure XDREAMY Plugin Settings :Configures weather and API keys.
  1. Navigate to Menu > Plugins > XDREAMY Control Plugin.
  2. Input your TMDB / OMDB API keys for enhanced movie poster fetching.
  3. Install oaWeather or MSNWeather from the feed and set your target city location.
