Fury-FHD Skin v5.8 for Enigma2: Features, Changelog & Installation Guide
Fury-FHD Skin v5.8 is a major update to the popular Full HD (1080p) interface skin for Enigma2 Linux satellite receivers. Designed for high aesthetic appeal and performance, version 5.8 introduces new circular InfoBar layouts, enhanced signal telemetry with dB readings, dedicated support for softcam management plugins, and a reduced footprint of just 12 MB for maximum menu fluidness.
Fury-FHD Skin v5.8 for Enigma2 Download & Installation Guide
What's New in Version 5.8 (Changelog)
  • New Circular InfoBar Screens: Added 2 circular InfoBar layouts — one minimalist option without posters, and one featuring dual circular poster displays.
  • Enhanced SecondInfobar Signal Screen: Now displays real-time signal quality in dB alongside active encryption/CAID decoding metrics.
  • Plugin Layout Additions: Added a dedicated custom layout screen for the Alternative Softcam Manager plugin.
  • Deep Black Color Theme: Added Color Option #12 for a pure dark black UI background.
  • Skin Setup & Update Fixes: Refreshed the skin control plugin screen and resolved direct online update issues on OpenATV images.
  • Size & Performance Optimization: Compressed the total skin package to 12 MB for faster loading times and lower RAM consumption.
Image & Software Compatibility Matrix
Image Distribution Supported Versions / Builds
OpenATV All Versions
EGAMI All Versions
PurE2 All Versions
OpenBH Versions 5.4 & 5.5.1
OpenViX Version 6.7
OpenPLi Foxbob build, Python 3.9.9, and Python 3.11 builds
Installation & Update Methods
1.Option 1: Direct Update via Skin Setup Plugin :
Fastest method for existing users.
If you already have a previous version installed, open the Fury-FHD Control Plugin from your receiver menu and execute the online update function directly.
2.Option 2: Single Terminal Command (Recommended) :
Automatic download & dependency resolution via SSH.
Connect to your receiver via SSH or Telnet (PuTTY) and run the following command:
opkg update && wget -q "--no-check-certificate" https://raw.githubusercontent.com/islam-2412/IPKS/refs/heads/main/fury/installer.sh -O - | /bin/sh
3.Option 3: Manual IPK / Script Installation :
For offline or FTP installation.
  1. Download the .ipk package or installer.sh script file below.
  2. Transfer the file to /tmp/ on your receiver via FTP (FileZilla or WinSCP).
  3. Install via terminal using opkg install --force-overwrite /tmp/*.ipk or execute the shell script.
enigma2-plugin-skins-fury-fhd_5.8_all.ipk Fury-FHD-installer.sh
