Mx PrioFHD Skin for Enigma2: Features, Setup & Download Guide
Mx PrioFHD is a custom, lightweight Full HD (1080p) user interface skin designed for Enigma2 satellite receivers (Vu+, Dreambox, Octagon, Zgemma, Gigablue). It replaces default menus, channel selection screens, and InfoBars with a high-contrast layout optimized for crisp typography, detailed CAID/ECM information, and smooth menu navigation without slowing down the receiver.
Fully compatible with Python 2 and Python 3 images (OpenATV 7.x, OpenBH, OpenPLi, EGAMI, PurE2, ViX, and Dreambox OS).
Mx PrioFHD Skin for Enigma2 Download & Installation Guide
MxPrioFHD-skin-2.thumb.jpg.88f8181d09255faa096280f5aa68063e.jpg MxPrioFHD-skin-.thumb.jpg.ae226aba39b3ef9c97837c6b81d4452b.jpg MxPrioFHD-skin-3.thumb.jpg.4203ea1f6a8c4b25bbd46e6d82df5e04.jpg
Key Features
  • Native 1080p FHD Interface: Clean graphical layout designed specifically for 1920x1080 displays.
  • Detailed Prio & ECM Display: InfoBar and SecondInfoBar show real-time ECM times, Active CAID, Provider ID, Hop counts, and softcam reader stats.
  • Optimized Channel Selection: Bouquet list view with EPG progress bars, channel numbers, and picon integration.
  • Low System Resource Usage: Lightweight XML rendering ensures zero menu lag and low RAM consumption.
  • Weather & Poster Support: Native compatibility with OAWeather and standard EPG poster renderers.
Compatibility Matrix
Skin Attribute Details
Resolution Full HD (1920x1080)
Python Support Python 2.7 & Python 3.10+
Supported Images OpenATV, OpenBH, OpenPLi, EGAMI, ViX, PurE2, Newnigma2
Package Formats .ipk (OE-Alliance) / .deb (Dreambox OS)
Quick Installation Guide
1.Upload Package to /tmp/ :
Transfers package to receiver memory.
Download the appropriate package format and upload the file to /tmp/ on your receiver via FTP (FileZilla or WinSCP).
2.Install via SSH / Terminal :
Executes skin installer script.
Connect via SSH/Telnet (PuTTY) and run:
  • For IPK Images (OpenATV, OpenPLi, EGAMI, etc.):
  • For DEB Images (Dreambox OS):
dpkg -i /tmp/*.deb
apt-get install -f -y
3.Activate Skin & Restart GUI :
Applies new visual interface.
Go to Menu > Setup > Usage & GUI > Skin Setup, select Mx PrioFHD, press OK, and restart the user interface.
Mx-PrioFHD-Skin.zip
