NCam v15.8 Softcam for Enigma2: Download, Features & Installation Guide
NCam v15.8 is an advanced emulator softcam based on OSCam source code, heavily optimized for Linux Enigma2 satellite receivers. Build 15.8 delivers enhanced ECM processing speed, automatic softcam key updating (PowerVu, Tandberg, BISS), optimized card reader drivers, and improved server connection stability across CCcam, Newcamd, and Gbox protocols.
Compatible with Python 2 and Python 3 images (OpenATV, OpenPLi, OpenBH, EGAMI, VTi, BlackHole, and Dreambox OS).
NCam v15.8 Softcam for Enigma2 Download & Setup Guide
Key Features & Improvements in v15.8
  • Ultra-Fast Zapping: Refined descrambling algorithms reduce channel decoding time and prevent micro-stuttering.
  • Auto-Update Softcam Keys: Automatically fetches and updates keys for PowerVu, Tandberg, and BISS channels without manual file editing.
  • Broad Architecture Support: Compiled binaries for ARM 4K, MIPS, and ARM64 (AArch64) processors.
  • Dual Package Availability: Available in .ipk for OE-Alliance distributions and .deb for Dreambox OS images.
  • Low System Resource Usage: Optimized memory footprint for legacy receivers and high-end 4K boxes alike.
Hardware & Image Compatibility
Package Format Supported Architecture Supported Images
IPK Packages ARM 4K & MIPS: Vu+, Octagon, Zgemma, Mut@nt, Edision, Gigablue OpenATV, OpenPLi, OpenBH, EGAMI, BlackHole, VTi, PurE2, OpenHDF
DEB Packages ARM64 / MIPS (Dreambox OS): DM900, DM920, DM520, DM820, DM7080, DM ONE / TWO Newnigma2, Dream Elite, OoZooN, GP4 / Gemini, Merlin5
Quick Installation Guide
1.Upload Package to /tmp/ :
Transfers installer to receiver system.
Upload the appropriate .ipk (for Vu+, Octagon, Zgemma) or .deb file (for Dreambox) to the /tmp/ folder via FTP (FileZilla or WinSCP).
2.Install via SSH / Terminal :
Installs softcam binaries and startup scripts.
Connect via SSH/Telnet (PuTTY) and run the installer command:
  • For IPK Images:
  • For DEB Images (Dreambox OS):
dpkg -i /tmp/*.deb
apt-get install -f -y
3.Upload Configuration Files :
Required for server reader authentication.
Transfer your configuration files (ncam.server, ncam.conf, ncam.user) to /etc/tuxbox/config/ncam/ (or /etc/tuxbox/config/).
4.Start NCam via Softcam Panel :
Activates softcam service.
Go to Menu > Setup > Softcam / CI > Softcam Panel, select NCam 15.8, and press Green (Start/Restart).
