CCcam v2.3.9 Softcam for Enigma2: Features, Installation & Download Guide
CCcam v2.3.9 is an updated release of the classic card-sharing emulator softcam for Linux Enigma2 satellite receivers. Build 2.3.9 provides enhanced ECM response times, updated Long ECM handling, improved server auto-reconnect routines, and full compatibility with modern Python 2 and Python 3 firmware images.
Compatible with all major Enigma2 distributions including OpenATV, OpenPLi, BlackHole, OpenBH, EGAMI, VTi, and Dreambox OS.
CCcam v2.3.9 Softcam for Enigma2 Download & Setup Guide
Key Features of CCcam 2.3.9
  • Fast Channel Zapping: Optimized decryption processing reduces ECM lag during satellite channel switching.
  • Stable Server Connectivity: Automatic handshake recovery ensures uninterrupted connection to C-lines and N-lines.
  • Low Memory Footprint: Extremely lightweight resource consumption, ideal for both high-end 4K receivers and legacy MIPS boxes.
  • Multi-Format Packaging: Available as .ipk for OE-Alliance distributions and .deb for official Dreambox OS.
Compatibility Matrix
Package Type Architecture & Hardware Supported Images
IPK Packages ARM 4K & MIPS: Vu+, Octagon, Zgemma, Mut@nt, Gigablue, Edision OpenATV, OpenPLi, BlackHole, OpenBH, EGAMI, VTi, OpenHDF, PurE2
DEB Packages Dreambox OS: DM900, DM920, DM520, DM820, DM7080, DM ONE/TWO Newnigma2, Dream Elite, OoZooN, GP4 / Gemini, Merlin5
Quick Installation & Setup Guide
1.Upload Config File :
Required for server authorization.
Transfer your CCcam.cfg file via FTP (FileZilla or WinSCP) to the /etc/ directory on your receiver.
2.Upload Package to /tmp/ :
Transfers plugin installer to system memory.
Upload the appropriate .ipk file (for Vu+, Zgemma, etc.) or .deb file (for Dreambox OS) to /tmp/.
3.Install via SSH Terminal :
Executes package installation.
Connect via SSH/Telnet (PuTTY) and run the installer command:
  • For IPK Images:
  • For DEB Images (Dreambox):
dpkg -i /tmp/*.deb
apt-get install -f -y
4.Start CCcam 2.3.9 :Activates softcam service.
Go to Menu > Setup > Softcam / CI > Softcam Panel, select CCcam 2.3.9, and press Green (Start/Restart).
