OpenSPA 8.7 Image for Vu+ Receivers: Download & USB Flashing Guide
OpenSPA 8.7 is a feature-packed, custom Linux Enigma2 firmware image specifically optimized for Vu+ satellite receivers. Built on an updated Python 3 environment and the OE-Alliance core, OpenSPA stands out for its exclusive SPA Panel, advanced media playback features, spzRemote interface, and seamless 4K IPTV stream processing.
Compatible with all Vu+ 4K Ultra HD models as well as legacy Vu+ MIPS HD receivers.
Key Features of OpenSPA 8.7
  • Exclusive SPA Panel: Built-in control panel for softcam activation, plugin downloads, backup management, and quick system tweaks.
  • Optimized IPTV & VOD Engine: Enhanced GStreamer and FFmpeg integration for fast zapping and smooth playback of 4K H.265/HEVC streams.
  • spzRemote & TVWeb: Advanced remote web control tools and custom web browsing integrations tailored for Enigma2.
  • Advanced EPG & Channel Manager: Integrated 7-day EPG importer and custom bouquet sorting built directly into the firmware.
  • High-Contrast SPA Skins: Default modern full-HD skins (SPA-FHD) designed for fluid navigation without menu latency.
Supported Vu+ Receiver Models
Architecture Model Series Package Extension
Vu+ ARM 4K Vu+ Duo 4K / Duo 4K SE, Uno 4K / Uno 4K SE, Zero 4K, Ultimo 4K, Solo 4K .zip (Flashing via USB)
Vu+ MIPS HD Vu+ Solo2, Duo2, Solo SE, Zero, Uno, Ultimo, Solo .zip (Flashing via USB)
Quick USB Flashing Guide
1.Prepare USB Drive :
Prepares flash drive for receiver bootloader.
Format a USB flash drive (16GB or smaller recommended) to FAT32.
2.Download & Extract Image :
Preserves required folder structure.
Download the OpenSPA 8.7 .zip archive matching your exact Vu+ model and extract it directly to the root of your USB drive. Ensure the directory path looks like USB:\vuplus\your_model_name\.
3.Flash Firmware via USB :
Triggers firmware deployment on boot.
  1. Turn OFF the receiver using the rear power switch.
  2. Insert the USB drive into the front USB port (or rear port if front is unavailable).
  3. Power ON the receiver. When the display shows "Press Power" (or touch button LED flashes), press the front panel Power Button to start flashing.
4.Reboot & Initial Setup :
Initializes new OpenSPA environment.
Wait for the installation to reach 100%. The receiver will reboot automatically. Remove the USB drive and complete the initial setup wizard on your TV screen.
(The files are available for direct download in the attachments section at the bottom of this thread.)openspa-8.7.001-vuduo4k-20260704_usb.zip
openspa-8.7.001-vusolo4k-20260704_usb.zip openspa-8.7.001-vusolose-20260704_usb.zip openspa-8.7.001-vuuno4kse-20260704_usb.zip openspa-8.7.001-vuultimo4k-20260704_usb.zip openspa-8.7.001-vuuno4k-20260704_usb.zip openspa-8.7.001-vuzero4k-20260704_usb.zip openspa-8.7.001-vuduo2-20260704_usb.zip openspa-8.7.001-vuzero-20260704_usb.zip
