WireGuard VPN v16.2 for Enigma2: Quick Installation & Setup Guide
WireGuard VPN v16.2 is a lightweight, high-performance VPN plugin built for Enigma2 Linux satellite receivers. Running directly inside the Linux kernel, WireGuard delivers significantly higher speeds and lower CPU usage than traditional OpenVPN, making it the ideal protocol for 4K IPTV streaming and secure browsing.
Compatible with Python 2 and Python 3 images (OpenATV 7.x, OpenBH, EGAMI 10.x, OpenPLi, and ViX).
WireGuard VPN v16.2 for Enigma2 Download & Setup Guide
Key Features
  • High Speeds: Maximum bandwidth efficiency for buffer-free 4K/HEVC IPTV streams.
  • Low CPU Overhead: Operates at the kernel level (wg0), keeping CPU consumption below 5%.
  • Instant Handshake: Fast connection startup and automatic reconnects under 100ms.
  • Provider Support: Works with .conf files from NordVPN, Surfshark, ExpressVPN, ProtonVPN, Mullvad, and self-hosted servers.
  • Leak Protection: Prevents IP and DNS leaks during stream playback.
Quick Installation Guide
1.Transfer Config File :
Required for VPN configuration.
Download your provider's wg0.conf file and upload it via FTP to /etc/wireguard/ on your receiver.
2.Install WireGuard Kernel Tools via SSH :
Installs core system components.
Connect via SSH/Telnet (PuTTY) and run:
opkg install wireguard-tools kernel-module-wireguard
3.Install Plugin IPK :
Deploys the plugin package.
Upload the attached IPK package to /tmp/ and execute:
4.Activate VPN Connection :
Activates encrypted tunnel.
Go to Menu > Plugins > WireGuard VPN, select your configuration profile, and press Green (Connect).
