Skin HDSuisse FHD for Enigma2: Download, Features & Setup Guide (2026)
Skin HDSuisse FHD for Enigma2: Download, Features, Customization & Installation Guide (2026)
The HDSuisse FHD skin is widely recognized as one of the cleanest, most responsive, and visually balanced user interfaces developed for Linux Enigma2 satellite receivers. Created with a minimalist Swiss design philosophy, this native 1920x1080 Full HD skin delivers high-contrast typography, crisp channel bouquet layouts, and crystal-clear InfoBars without burdening the receiver's CPU or memory.
Fully compatible with both Python 2 and modern Python 3 Enigma2 images—including OpenATV 7.x, OpenPLi, OpenBH 5.x/6.x, EGAMI 10.x, ViX, and PurE2—HDSuisse FHD offers an ideal balance of elegance and speed.
Hdsuisse-5.thumb.jpg.4035c4617c7db016d63a8366bb8f2b45.jpg Hdsuisse-3.thumb.jpg.5e9b20c3c2f479ebbbe10c8527306121.jpg Hdsuisse-2.thumb.jpg.fea4b83b214bff0044c072798225d3f1.jpg Hdsuisse-8.thumb.jpg.4a60a382097698aca12ad72857d2ed8c.jpg
1. Key Features of HDSuisse FHD
While many feature-heavy skins introduce menu delay and slow down channel zapping, HDSuisse FHD utilizes optimized XML rendering structures to ensure immediate button responses and smooth navigation.
[Satellite / Cable / IPTV Signal] ──► [DVB Demuxer Engine]
[HDSuisse FHD Skin Core] ──► [Minimalist InfoBar & SecondInfoBar]
[Custom Picon Engine & EPG Grid] ──► [1080p Crystal Clear UI]
  • Ultra-Clean InfoBar Architecture: Displays vital broadcast parameters at a glance, including channel resolution (1080i, 1080p, 2160p HDR), audio codecs (Dolby Digital, AAC), signal strength meters (SNR/AGC percentage), and orbital satellite positions.
  • Extended SecondInfoBar: Displays detailed ECM times, crypt system identification (CAID, Provider ID, Hop count), local/remote reader info, and extended program descriptions.
  • Minimalist Channel Selection (Bouquet) View: Features multi-line channel views with built-in progress bars, event percentage indicators, and clean picon alignment.
  • Low System Resource Overhead: Uses minimal background skin renderers, maintaining idle RAM usage near ~150MB—making it suitable for both flagship 4K receivers and mid-range HD boxes.
  • Native Weather & EPG Integration: Seamlessly displays current weather conditions and multi-day forecasts using OAWeather or MSN Weather plugins.
2. Firmware Compatibility & Package Information
HDSuisse FHD is packaged as an architecture-independent IPK archive compatible with all major Enigma2 distributions.
Package Name Enigma2 Distribution Python Version Download Package File
Skin HDSuisse FHD Universal (OE-Alliance / OpenPLi) Python 2.7 & Python 3.10+ enigma2-skin-hdsuisse.fhd_merlin_8.3_all.deb
3. Step-by-Step Installation Guide
Follow this sequence to transfer and install the skin package on your receiver using FTP and SSH/Terminal.
1.Download & FTP Transfer IPK File :
Transfers the IPK archive to the receiver.
  1. Download the attached enigma2-plugin-skins-hdsuisse-fhd_all.ipk package to your computer.
  2. Connect to your receiver using an FTP client (FileZilla or WinSCP) with your receiver's IP address (User: root).
  3. Upload the .ipk file into the /tmp/ directory on your box.
2.Update Package Index via SSH :Refreshes local opkg package indexes.
Open terminal access (PuTTY or Terminal) and log in to your box, then run the package refresh command:
3.Execute IPK Installation Command :
Deploys skin layout and graphical assets.
Install the skin package by executing the following terminal command:
4.Activate Skin & Restart GUI :
Applies the new skin to Enigma2.
  1. Once the terminal reports successful installation, restart your Enigma2 GUI.
  2. On your remote control, go to Menu > Setup > Usage & GUI > Skin Setup (or Menu > System > Skin).
  3. Select HDSuisse FHD, press OK, and confirm restarting the GUI.
4. Post-Installation Picon & Weather Setup
To ensure channel logos and weather widgets display properly within HDSuisse FHD, verify the following configuration paths:
A. Channel Picon Directories
Transfer your 220x132 or 400x240 transparent channel picons to one of these standard system paths via FTP:
  • /usr/share/enigma2/picon/ (Internal Storage)
  • /media/usb/picon/ (External USB - Recommended)
B. Installing Weather Dependencies
If weather info appears blank on the main screen, install the missing weather component via terminal:
opkg install enigma2-plugin-extensions-oaweather
Q1: How do I recover if a Green Screen (GS) crash loop occurs after activating the skin?
A: Connect to your receiver via FTP, navigate to /usr/share/enigma2/, delete the HDSuisse-FHD directory, and restart the receiver. Enigma2 will automatically fallback to the default image skin.
Q2: Does HDSuisse FHD support 4K Picons?
A: Yes. The skin automatically scales high-resolution picons (400x240 or 220x132) to fit the InfoBar and channel bouquet display slots.
Q3: Can I customize font sizes or accent colors in HDSuisse FHD?
A: Color schemes and font scaling can be adjusted directly through the built-in skin setup manager under Menu > Setup > GUI > Skin Setup > HDSuisse Setup (if supported by your image build).
