Skin Premium FHD v2.4 for Enigma2: Download, Features & Setup Guide (2026)
Skin Premium FHD v2.4 for Enigma2: Download, Features, Customization & Installation Guide (2026)
The Premium FHD v2.4 skin is one of the most polished, responsive, and visual-rich user interfaces available for Linux Enigma2 satellite receivers. Designed natively for 1920x1080 Full HD resolution, version 2.4 brings complete compatibility with both Python 2 and modern Python 3 Enigma2 images (including OpenATV 7.x, OpenBH 5.x/6.x, OpenPLi, EGAMI 10.x, PurE2, and ViX).
Whether you are looking for clean channel selection screens, rich poster integration for VOD services, or detailed ECM/tuner InfoBars, Premium FHD v2.4 combines high aesthetic appeal with lightweight CPU rendering.
premium-skin-10.png.53468e7245e6943104d849045a33d346.png premium-skin-2.png.fc0248b772b000a5f825d40f4bfed4ee.png premium-skin-7.png.6b970b816f48da02923d7ed08d0c2b21.png
premium-skin-5.png.b18a732553a35d340fbafa60734db9b9.png premium-skin-11.png.935066fd172c8fd757eb76d12c429e2b.png premium-skin-6.png.9d60594ab0496c2dd91fbc812bc3238c.png
1. Key Features of Premium FHD v2.4
Unlike generic skins that cause UI stuttering on older processors, Premium FHD v2.4 is optimized to maintain fast menu navigation and instantaneous channel zapping while rendering rich media assets.
[Satellite / Cable / IPTV Signal] ──► [Enigma2 Demuxer]
[Premium FHD v2.4 Skin Engine] ──► [OAWeather & PosterX Renderers]
[Dual InfoBar / Custom Channel Selection] ──► [1080p FHD UI Display]
  • Multi-InfoBar Configurations: Switch seamlessly between standard compact InfoBars and extended SecondInfoBars containing tuner frequencies, SNR/AGC meters, CAID/ECM information, and encryption protocols.
  • PosterX & VOD Integration: Automatically fetches movie/TV series posters and backdrops for active programs, E2iPlayer streams, Xstreamity IPTV categories, and recorded files.
  • Custom Channel Selection Layouts: Multiple bouquet list layouts supporting single-line, dual-line with EPG progress bars, picons, and next-program event previews.
  • Native Weather Widget Integration: Full support for OAWeather and MSN Weather components directly on the main screen and event info panels.
  • Skin Control Plugin Support: Customize accent colors, clock styles, font sizes, transparency levels, and layout styles directly from the receiver GUI without editing XML files manually.
2. Firmware Compatibility & Attached Package Files
Premium FHD v2.4 is packaged as a universal IPK archive compatible with OE-Alliance and OpenPLi-based firmware builds.
Package Name Enigma2 Architecture Python Compatibility Attachment Package File
Skin Premium FHD v2.4 Universal (OE-Alliance / OpenPLi) Python 2.7 & Python 3.10+ enigma2-plugin-skins-premium-fhd_2.4_all.ipk
Skin Premium Black FHD v2.4 Universal (OE-Alliance / OpenPLi) Python 2.7 & Python 3.10+ enigma2-plugin-skins-premium-fhd-black_2.4_all.ipk
Skin Premium Blue FHD v2.4 Universal (OE-Alliance / OpenPLi) Python 2.7 & Python 3.10+ enigma2-plugin-skins-premium-fhd-blue_2.4_all.ipk
(The installation IPK file is available for direct download in the attachments section at the bottom of this thread.)
3. Step-by-Step Installation Procedure
You can install the attached IPK package using FTP and terminal access (PuTTY / SSH) or directly through your image's built-in Software Manager.
1.Download & Transfer IPK File :
Required for transferring installation files.
  1. Download the attached enigma2-plugin-skins-premium-fhd_2.4_all.ipk package to your computer.
  2. Connect to your receiver via FTP (FileZilla or WinSCP) using your box IP address (User: root).
  3. Transfer the IPK file into the /tmp/ directory on your receiver.
2.Install Dependencies via SSH / Terminal :
Ensures all graphics and renderer packages are present.
Connect to your box via SSH/Telnet using PuTTY or Terminal, then run the update command to ensure required renderers (python-requests, enigma2-plugin-extensions-oaweather) are installed:
3.Execute IPK Installation Command :
Deploys skin XML and graphical components.
Run the following command in the terminal to force installation of the skin and auto-resolve dependencies:
4.Activate Skin & Restart Enigma2 :Applies new UI configuration.
  1. Once the terminal reports Installation complete, reboot your Enigma2 GUI.
  2. On your remote, navigate to Menu > Setup > Usage & GUI > Skin Setup (or Menu > System > Skin).
  3. Select Premium FHD v2.4 from the list, press OK, and confirm restarting the GUI.
4. Post-Installation Dependencies & Weather Setup
To enable all dynamic widgets (weather, posters, and extra channel info), run these helper commands via SSH if any component displays blank data:
A. Install Missing Poster & Rendering Components
opkg install python3-requests enigma2-plugin-extensions-oaweather
B. Configuring Picons Path
Ensure your channel logo picons are placed in one of the standard system search paths for automatic display:
  • /usr/share/enigma2/picon/ (Internal Flash)
  • /media/usb/picon/ (USB Drive - Recommended)
  • /media/hdd/picon/ (Hard Disk Drive)
Q1: What should I do if my receiver gets stuck on a Green Screen (GS) after activating the skin?
A: If a missing renderer causes a crash loop, connect via FTP, navigate to /usr/share/enigma2/, delete the Premium-FHD folder, and restart your box. It will automatically revert to the default skin.
Q2: How do I change the color scheme or layout of Premium FHD v2.4?
A: Go to Plugins > Premium FHD Control (or Menu > Setup > GUI > Skin Setup > Premium FHD Setup). Here you can toggle between dark/light themes, change accent colors, and adjust channel list views.
Q3: Is Premium FHD v2.4 compatible with DreamOS (DM900 / DM920)?
A: This IPK build is designed for OE-Alliance (OpenATV, OpenBH, EGAMI, OpenPLi). For DreamOS images (GP4 / Original DMM), a converted .deb package version is required.
