Fix IPTV EPG Not Loading: Xtream Codes, Time Shift & XMLTV Guide (2026)
Missing channel guides, offset broadcast schedules, or seeing "No Information" across your EPG timeline are common issues when streaming live TV on Android TV, Firestick, and Smart TVs.
EPG sync failures usually stem from XMLTV parsing timeouts, incorrect timezone offsets, or heavy playlist structures.
This technical guide covers how to fix EPG loading errors across TiviMate, OTT Navigator, and IPTV Smarters Pro.
EPG Error & Fix Quick Matrix
Common EPG Error Root Cause Technical Solution
"No Information" on all channels EPG URL timeout or corrupt XMLTV cache Clear EPG Cache & Force Source Refresh
Broadcast schedule shifted by 1-2 hours Timezone / UTC offset mismatch Adjust EPG Time Shift parameter
EPG missing on specific channels Mismatched channel ID callsigns Assign EPG Source manually per channel
Slow playlist startup delay Heavy EPG payload parsing Enable Past Days EPG Store Limit
1. Fix Missing EPG on Xtream Codes API
If your EPG guide displays empty channels after adding an Xtream Codes login, force an explicit server reload.
Step-by-Step Fix:
  1. Open app Settings > EPG > EPG Sources.
  2. Select your active EPG source and click Update EPG.
  3. If the update fails, navigate to Playlists > Edit Playlist.
  4. Ensure the EPG URL matches the correct server format:
    http://your-domain.com:8080/xmltv.php?username=USER&password=PASS
  5. Save settings and clear local temporary app cache.
2. How to Fix EPG Time Shift & Sync Offsets
If a live football match starts at 20:00 but your guide shows it scheduled for 21:00, your app is reading UTC timestamps without local timezone conversion.
How to Adjust Time Shift:
  1. Go to Settings > EPG > EPG Time Shift.
  2. Adjust the offset hours:
    • If schedule is 1 hour ahead: Set offset to -1:00.
    • If schedule is 1 hour behind: Set offset to +1:00.
  3. Apply changes and refresh the EPG guide interface.
3. Manual EPG Assignment for Missing Channels
Some local or regional channels fail to auto-assign program data due to slight variations in channel callsign naming.
Manual Channel Mapping:
  1. Open your channel guide, highlight the channel with missing EPG, and long-press the OK/Select button.
  2. Select Custom Options > Assign EPG (or Edit EPG).
  3. Type the channel name in the search bar.
  4. Select the matching channel callsign from the global database list.
4. Optimize EPG RAM Storage & Speed Up App Startup
Downloading 7 days of EPG data for 50,000 channels consumes massive system memory, causing apps to lag or crash on Firestick and Smart TVs.
Optimization Steps:
  1. Go to Settings > EPG > Advanced.
  2. Change Days to Keep EPG from 7 Days down to 1 or 2 Days.
  3. Enable Update EPG only on Wi-Fi/LAN.
  4. Turn on Store EPG in RAM (if using devices with 3GB+ RAM like NVIDIA Shield or Fire TV Cube).
Q1: Why does EPG update fail on Wi-Fi but work on mobile data?
A: Your ISP DNS may be blocking the provider's xmltv.php download link. Switch your device DNS settings manually to Cloudflare (1.1.1.1) or Google (8.8.8.8).
Q2: Can I use an external EPG URL with Xtream Codes login?
A: Yes. Apps like TiviMate and OTT Navigator allow adding custom secondary XMLTV links (.xml / .gz) and mapping them directly alongside your provider source.
Q3: How often should I set automatic EPG updating?
A: Setting automatic update intervals to Every 24 Hours at 04:00 AM is optimal. Updating too frequently wastes bandwidth and slows down app launch times.
