How to Fix Smart TV App Crashes & "Out of Memory" Errors on Samsung, LG & Sony (2026 Fix)
When running heavy media applications or loading large playlists (20,000+ VODs & channels) on Samsung (Tizen), LG (webOS), or Sony (Google TV), users often experience sudden application crashes back to the TV Home Screen, extreme remote control lagging, or an explicit error message: "App will now restart to free up memory" or "Out of Memory / Storage Full".
Unlike Android TV devices with flexible RAM managers, Smart TVs use light, web-based operating systems with very limited system RAM (often only 1GB to 1.5GB) reserved for applications. When an app accumulates video buffer logs, channel icons (EPG cache), and background web socket data, a Memory Leak occurs, forcing the TV OS to kill the app process instantly.
In this technical guide, we break down how to stop Smart TV memory leaks, perform a deep system cache purge, and configure app settings to prevent memory crashes.
Smart TV RAM & Memory Crash Diagnostic
Error / Crash Symptom Root Cause in Smart TV OS Recommended Technical Solution
App instantly closes to Home Menu mid-stream RAM exhaustion due to EPG/Channel icon cache accumulation Limit EPG History Days & Disable Channel Logos in app settings
"App will restart to free memory" (LG webOS) WebKit browser engine memory leak Execute Cold System Reboot & Clear LG Web Browser Cache
Remote input delay & frozen video frame Background system care logs filling flash storage Perform Samsung Device Care / Storage Memory Purge
App crashes on startup when loading playlist M3U file size exceeds TV Web API parsing limit Switch to Xtream Codes API or filter unwanted playlist groups
1. Execute a "Cold Reboot" (Clear RAM Hardware Cache)
Turning off your Smart TV using the remote control does not power off the system—it merely puts the TV into a low-power "Standby / Sleep Mode." Over weeks, active app processes remains frozen in system RAM, leading to memory corruption.
A Cold Reboot completely flushes system RAM chips and clears temporary OS socket caches.
How to Cold Reboot Samsung Smart TVs:
  • Hold down the Power Button on your Samsung remote control for 5–10 seconds continuously until the TV screen turns off AND the Samsung boot logo reappears on screen.
How to Cold Reboot LG Smart TVs:
  • Unplug the TV's power cable directly from the wall outlet. Hold the physical power button on the TV chassis for 10 seconds, then wait 60 seconds before plugging it back in.
How to Cold Reboot Sony Google TVs:
  • Hold the Power button on the remote, then select Restart on the screen menu (or go to Settings > System > Restart).
2. Purge System Web Browser & App Caches
Most Smart TV apps (such as IBO Player, SmartOne, SS IPTV) run inside a sandboxed WebKit Web Browser Engine. When you navigate channels, web image thumbnails build up inside the browser cache, consuming internal storage.
Clearing Cache on Samsung (Tizen OS):
  1. Go to Settings > Support > Device Care.
  2. Run Start Device Care to optimize RAM and system processes.
  3. Select Manage Storage.
  4. Scroll to your installed media player apps, select View Details, and click Clear Cache and Clear Data.
Clearing Cache on LG (webOS):
  1. Open the built-in Web Browser app on your LG TV.
  2. Click the Menu (3 dots) in the top right corner and open Settings.
  3. Scroll down and click Clear Browsing Data (Clear Cache and Cookies).
  4. Go to Settings > General > OLED Care / Device Care and run Memory Optimization.
3. Configure App Settings to Prevent Memory Leaks
If your active playlist contains tens of thousands of channels and VOD titles, rendering channel icons and electronic program guides (EPG) will instantly overwhelm a Smart TV's 1GB RAM budget.
Optimize App Performance:
  1. Switch Login Method: Stop loading massive raw .m3u text files containing 100,000+ lines. Use Xtream Codes API (Server URL, Username, Password) instead. Xtream Codes fetches data dynamically on demand rather than loading the entire database into TV RAM.
  2. Disable Channel Logos: Inside your player app's settings (e.g., FlixIPTV or SmartOne), turn Channel Logos / Icons to OFF or Low Quality.
  3. Limit EPG Retention: Change EPG Keeping Period from 7 Days down to 1 Day or Current Day Only.
  4. Disable Unused Categories: Log into your app portal via web browser and hide unwanted country groups (e.g., international categories or adult sections you don't watch) to drastically reduce memory overhead.
4. Disable Silent Background System Diagnostics
By default, Smart TVs continuously log system diagnostics, usage data, and voice recognition logs in the background, consuming valuable CPU cycles and system memory.
Optimization Steps:
  • Samsung: Go to Settings > Terms & Privacy > Privacy Choices and disable Viewing Information Services and Interest-Based Advertisements.
  • LG: Go to Settings > General > System > Additional Settings > User Agreements and uncheck Personalized Ads and Voice Information Processing.
Q1: Why does my Smart TV app crash only on VOD movies and not live channels?
A: VOD movie posters and high-bitrate video buffers require significantly more RAM memory than standard live TV streams. Clearing the app cache and using Xtream API resolves VOD crashes.
Q2: Can I install an external USB drive to add more RAM to my Smart TV?
A: No. USB drives only expand internal file storage capacity for apps; they cannot expand physical System RAM memory.
Q3: How often should I perform a Cold Reboot on my Smart TV?
A: Performing a Cold Reboot once a week keeps the TV's RAM clean, prevents background memory leaks, and maintains fast app loading speeds.
