Amlogic S905X4 vs Realtek vs Rockchip: Best TV Box Chipsets for 4K Streaming (2026 Guide)
When purchasing an Android TV Box or streaming device, most users focus primarily on RAM capacity (e.g., 2GB vs 4GB). However, the real bottleneck determining stream stability, decoding speed, and picture quality is the System-on-Chip (SoC) processor architecture.
In 2026, streaming standards have shifted heavily toward high-efficiency codecs like AV1 and dynamic display features like Hardware Auto Frame Rate (AFR) Matching. Choosing a TV Box with an outdated processor causes micro-stuttering during sports broadcasts, high thermal throttling, and unsupported 4K HDR color profiles.
In this hardware technical guide, we compare the dominant TV Box chipsets—Amlogic S905X4 / S905X5, Realtek RTD1319 / RTD1619B, and Rockchip RK3566 / RK3588—to help you select the ultimate media processor for live TV and VOD streaming.
TV Box Chipset Performance Breakdown
Processor Chipset Hardware AV1 Decoding Hardware AFR Support Thermal Efficiency Primary Streaming Use Case
Amlogic S905X4 / S905X5 Native (Hardware) Excellent (Android TV OS API) High (Low heat generation) Best Overall for Live TV, TiviMate & General Streaming
Realtek RTD1619B Native (Hardware) Superior (System Level) Moderate Best for Premium 4K HDR VOD & Lossless Audio Passthrough
Rockchip RK3566 / RK3588 Limited (RK3588 only) Poor / App Dependent Moderate to Low Best for Emulation / Media Servers, Weak for Live TV OS
1. Why AV1 Codec Support Matters for Modern Live Streaming
AV1 (AOMedia Video 1) is an open-source video compression format designed to replace HEVC (H.265). AV1 delivers 30% better compression efficiency than H.265, allowing servers to stream pristine 4K video at 60FPS using significantly less internet bandwidth.
Processor Capability:
  • Amlogic S905X4 & S905X5: Feature dedicated hardware AV1 video decoding units, decoding 4K @ 60FPS streams using under 15% CPU load.
  • Rockchip RK3566 / Cheap Budget Boxes: Lack dedicated AV1 hardware decoders. They rely on software decoding, which overloads CPU cores, causing extreme heating, battery drain, and video frame drops.
2. Auto Frame Rate (AFR) Matching for Smooth Sports Playback
Live European football broadcasts are produced at 50Hz (50 FPS), while American broadcasts run at 60Hz (60 FPS) and movies play at native 24Hz (23.976 FPS).
If your TV Box runs locked at 60Hz while displaying a 50Hz broadcast, your TV is forced to perform frame insertion (judder), causing visible micro-stuttering whenever the camera moves fast across a stadium.
Chipset AFR Performance:
  • Amlogic (S905X4): Seamlessly integrates with Android TV OS 11+ System Auto Frame Rate APIs, allowing player apps like TiviMate to automatically match your TV display refresh rate to the exact stream frame rate.
  • Realtek: Features proprietary hardware-level precision frame matching, making it the preferred choice for enthusiasts running dedicated media players like Formuler or Zidoo.
  • Rockchip: Poor system API support for dynamic refresh rate switching, resulting in persistent motion judder on live sports streams.
3. Thermal Throttling & Power Consumption
Low-end TV boxes using budget processors suffer from high thermal output under heavy load. When CPU temperatures exceed 70°C, the processor automatically throttles its operating clock frequency down by 40–50% to prevent hardware damage, resulting in sudden stream buffering.
  • Amlogic S905X4 (12nm Process): Highly power-efficient architecture designed for fanless passively cooled streaming sticks and boxes.
  • Rockchip RK3588 (8nm Process): Extremely powerful octacore CPU, but requires large heatsinks or active cooling fans to prevent thermal throttling during extended 4K playback.
Summary: Which Processor Should You Choose?
  1. For General 4K Live Streaming & TiviMate: Choose an Amlogic S905X4 or S905X5 device (e.g., Mecool KM2 Plus, Chromecast with Google TV 4K, or Xiaomi TV Box S 2nd Gen).
  2. For High-End Home Cinema & Local 4K HDR Files: Choose a Realtek RTD1619B box (e.g., Zidoo or Dune HD platforms) for superior color space rendering and audio bitstreaming.
  3. Avoid Cheap Generic Boxes: Skip unnamed Android TV boxes featuring old Rockchip (RK3328 / RK3528) or Allwinner (H616 / H618) chips, as they lack certified Widevine L1 DRM keys and proper hardware video pipelines.
Q1: Why does Widevine L1 DRM certification matter for streaming devices?
A: Widevine L1 is hardware-level encryption required to play official streaming apps (Netflix, Prime Video, Disney+) in full 1080p or 4K. Non-certified chipsets fall back to Widevine L3, locking resolution to 480p SD quality.
Q2: Is 2GB of RAM enough on an Amlogic S905X4 device?
A: Yes, for pure media playback. Android TV OS handles memory efficiently. However, 4GB of RAM provides better multitasking headroom if you keep multiple player apps open simultaneously.
Q3: What is the difference between Amlogic S905X3 and S905X4?
A: The S905X4 adds native AV1 hardware video decoding support and natively ships with newer Android TV OS versions, whereas the older S905X3 lacks hardware AV1 support.
