How to Fix eARC Audio Lag & Surround Sound Dropouts on Smart TVs (2026 Guide)
When streaming live broadcasts, movies, or sports events on Samsung (Tizen), LG (webOS), or Sony (Google TV) connected to an external Soundbar or AV Receiver via HDMI eARC / ARC, users frequently encounter frustrating sound issues.
The most common problems include audio lip-sync delay (where sound lags behind the video actor's lips), sudden audio drops or crackling, or complete silence when switching to channels broadcasting multi-channel Dolby Digital (AC3 / EAC3) or DTS surround audio.
In this technical setup guide, we break down why HDMI eARC handshakes fail during live stream decoding and provide step-by-step calibration steps for Samsung, LG, and Sony Smart TVs.
Sound Synchronization & Passthrough Matrix
Sound Issue Primary Underlying Cause Recommended Technical Fix
Audio lags behind video by 200ms+ Heavy TV video processing delay Enable eARC Passthrough & Turn ON Game / PC Mode
No sound on Dolby Digital 5.1 streams Soundbar lacks AC3 / EAC3 decoding hardware Set TV Digital Audio Output to PCM / Auto
Random audio popping or silent gaps Bandwidth bottleneck on legacy HDMI cable Upgrade to an Ultra High Speed HDMI 2.1 Cable (48Gbps)
Audio sync shifts when changing channels Dynamic Frame Rate / Audio Bitstream mismatch Turn OFF AV Sync Adjustment on TV and use player offset
1. Configure HDMI eARC Mode & Bitstream Passthrough
By default, many Smart TVs perform internal audio re-encoding (converting incoming stream audio into PCM before sending it to the soundbar). This extra processing step creates noticeable audio latency.
Configuring Passthrough forces the Smart TV to send raw digital audio directly to your soundbar without delay.
Calibration for LG Smart TVs (webOS):
  1. Go to Settings > Sound > Sound Out and select Use External Speaker (HDMI eARC/ARC).
  2. Go to Advanced Settings > Digital Sound Output.
  3. Change setting from Auto to Pass Through.
  4. Set eARC Support to ON.
Calibration for Samsung Smart TVs (Tizen OS):
  1. Go to Settings > Sound > Expert Settings.
  2. Set HDMI-eARC Mode to Auto.
  3. Set Digital Output Audio Format to Pass Through (if greyed out, start a surround sound stream first).
Calibration for Sony Smart TVs (Google TV):
  1. Go to Settings > Display & Sound > Audio Output.
  2. Toggle eARC Mode to Auto.
  3. Set Digital Audio Out to Prioritize Pass Through (or Auto 1).
2. Fix Audio Delay Mismatches (Lip-Sync Calibration)
If video processing features (such as 4K upscaling or Motion Smoothing) introduce a display lag, you can calibrate the audio timing offset to match the screen output perfectly.
Recommended Steps:
  1. Turn OFF secondary TV sound processors like Dolby Atmos for TV Speakers or AI Sound Pro while using an external soundbar.
  2. Navigate to your TV's audio settings:
    • LG: Sound > Advanced Settings > Match Screen and Sound > TV Speaker Delay / Bypass. Select Bypass for zero-latency pass-through.
    • Samsung: Sound > Expert Settings > Audio Delay. Adjust the value down to 0 or adjust manually if audio arrives before video.
    • Sony: Display & Sound > Audio Output > A/V Sync. Set to Auto or On.
3. Resolve Dolby Digital / DTS Codec Conflicts in TV Apps
Smart TV streaming applications (such as IBO Player, SmartOne, or FlixIPTV) handle audio streams based on the TV operating system's internal decoders.
If a channel uses an unsupported audio codec:
  1. Open your player app's internal Settings > Audio.
  2. Switch Audio Decoder from Hardware (HW) to Software (SW) or FFmpeg.
  3. If connected via an optical TOSLINK cable instead of HDMI eARC, disable Dolby Digital Plus (EAC3) inside app settings, as optical cables only support standard Dolby Digital (AC3) or 2-channel PCM.
4. Hardware Check: HDMI 2.1 Cable & Port Requirements
eARC (Enhanced Audio Return Channel) requires high bandwidth to handle uncompressed 5.1 and 7.1 channel audio profiles.
  • Port Check: Ensure your HDMI cable is plugged strictly into the port labeled HDMI eARC / ARC on the TV (usually HDMI 2 or HDMI 3).
  • Cable Standard: Use an Ultra High Speed HDMI 2.1 cable. Standard or older HDMI cables lack the dedicated data lines required for stable eARC bitstream transmission, leading to random 1-second audio drops.
Q1: What is the difference between ARC and eARC?
A: ARC (Audio Return Channel) is limited to compressed 5.1 audio (Dolby Digital). eARC (Enhanced ARC) offers significantly higher bandwidth, supporting uncompressed Dolby TrueHD, Dolby Atmos, and 7.1 DTS-HD Master Audio without sync latency.
Q2: Why does audio desync only happen on 4K channels?
A: 4K video streams require significantly more hardware decoding time than 1080p streams. If Passthrough is disabled, the TV renders the audio faster than the 4K video frames, causing a lip-sync delay.
Q3: Should I connect my TV box directly to the Soundbar or the TV?
A: If your Soundbar has HDMI Pass-Through ports, connecting your TV Box directly to the Soundbar input (and then Soundbar to TV) completely eliminates lip-sync delay issues.
