How to Fix Downloader Code Connection Errors & Missing Developer Options on Firestick (2026 Guide)
The Downloader app by AFTVnews is the most essential utility for Amazon Fire TV Stick users, allowing effortless side-loading of media applications, utility tools, and custom players using short numeric download codes.
However, users frequently encounter two major technical roadblocks:
  1. "Status: Connection Failed" or "Error 403 / Access Denied" when entering Downloader shortcodes.
  2. Missing "Developer Options" inside system settings, preventing the installation of downloaded .apk files on Fire OS 7, Fire OS 8, and Fire TV Cube devices.
In this comprehensive troubleshooting guide, we detail how to restore missing Developer Options, bypass Downloader connection timeouts, and fix file path download errors.
Downloader Diagnostic & Fix Summary
Error Symptom Root Cause Technical Fix Action
Developer Options missing in Settings Hidden by Amazon default OS update policy Click "About > Fire TV Stick" 7 times to unhide
"Connection Failed / Timeout" ISP blocking Downloader redirect domain Change DNS to Cloudflare (1.1.1.1) or clear app data
"Install Unknown Apps" greyed out Amazon Kids profile or Knox restriction active Switch to Main Admin Profile & enable storage permissions
Download completes but no "Install" prompt Missing JavaScript Plugin / Storage Full Install Downloader Browser Plugin or clear storage
1. How to Unhide Missing "Developer Options" on Fire OS
Amazon hid the Developer Options menu by default in Fire OS system updates. Without enabling this menu, Fire OS will not allow Downloader to install external applications.
Step-by-Step Instructions:
  1. Open Settings (Gear Icon) from your Firestick Home screen.
  2. Select My Fire TV.
  3. Click on About.
  4. Highlight your primary device name (e.g., Fire TV Stick 4K Max or Fire TV Stick Lite).
  5. Press the Select / Center Button on your remote 7 times repeatedly.
  6. A toast notification will appear at the bottom: "No need, you are already a developer."
  7. Press the back button once; Developer Options will now be permanently visible under the My Fire TV menu.
2. Enable "Install Unknown Apps" for Downloader
Once Developer Options are visible, you must explicitly give Downloader permission to trigger the Android package installer.
Configuration Steps:
  1. Go to Settings > My Fire TV > Developer Options.
  2. Select Install unknown apps (or Apps from Unknown Sources).
  3. Locate Downloader in the list and switch it to ON.
  4. Go back to Settings > Applications > Manage Installed Applications > Downloader.
  5. Select Permissions and ensure Storage / Files and Media is set to Allowed.
3. Fix "Status: Connection Failed" & Code Redirect Errors
When entering numeric Downloader codes (e.g., short 5 or 6-digit codes), Downloader redirects the request through aftv.news shorteners. If your Internet Service Provider blocks this redirect domain or DNS resolution fails, the download aborts.
Fix Method 1: Change Firestick DNS Settings
  1. Go to Settings > Network.
  2. Forget your Wi-Fi network and reconnect using Advanced IP Settings.
  3. Assign a static IP and update DNS entries:
    • Primary DNS: 1.1.1.1 (Cloudflare)
    • Secondary DNS: 8.8.8.8 (Google)
Fix Method 2: Install Downloader Browser Plugin
Some download URLs point to file hosts requiring JavaScript execution.
  1. Open the Downloader app and go to the Home / URL field.
  2. Enter the official browser plugin link: browser.aftvnews.com.
  3. Download and install the Downloader Browser Plugin.
  4. Restart Downloader; it will now render complex web links and redirects seamlessly.
4. Clear Downloader App Cache & Data
If Downloader repeatedly hangs at "Connecting..." or fails to save files to system storage, the local app database or cache folder may be corrupted.
  1. Go to Settings > Applications > Manage Installed Applications.
  2. Scroll down and select Downloader.
  3. Click Force Stop, then click Clear Cache.
  4. Click Clear Data (this will reset the app without deleting installed applications).
  5. Relaunch Downloader and grant storage access when prompted.
Q1: Why does Downloader show "Error 403 Forbidden"?
A: Error 403 means the hosting server hosting the APK file is blocking generic Amazon User-Agents or request headers. Using a direct APK URL instead of a shortened code often bypasses this block.
Q2: Does Downloader work on Fire TV Smart TVs (Insignia / Toshiba / Xiaomi)?
A: Yes. The process is identical across all Fire OS devices, including Fire TV-powered Smart TVs.
Q3: Do I need a computer to download APK files using Downloader?
A: No. Downloader fetches, downloads, and executes package installations directly on your Firestick without needing a PC or USB flash drive.
