How to Fix Color Washout & HDR Playback Issues on Android TV Boxes (2026 Guide)
When streaming movies, TV shows, or 4K sports broadcasts on an Android TV Box, users often experience muted colors, dark crushed shadows, or a noticeable gray tint over the image.
This issue occurs when your Android TV Box forces HDR (High Dynamic Range) mode continuously across standard SDR content, or when the box fails to automatically negotiate the correct YUV Color Space / Chroma Subsampling with your TV's HDMI port.
In this technical display calibration guide, we detail how to set up dynamic HDR switching, adjust deep color settings, and calibrate hardware video renderers on Android TV OS.
Display Mismatch Symptoms & Resolution Matrix
Picture Issue Root Cause Technical Calibration Fix
Washed-out colors on normal TV channels Forced SDR-to-HDR conversion active Set HDR Mode to Auto / Match Content
Dark scenes look completely black (crushed) Mis-matched RGB Range (Full vs. Limited) Set Color Space to YCbCr 4:2:2 10-bit
Purple / Pink screen tint during video Unsupported Dolby Vision profile decoding Disable Dolby Vision or switch player renderer
Micro-stutter during 4K HDR playback Dynamic Refresh Rate (AFR) sync conflict Enable Match Content Frame Rate in display settings
1. Configure Dynamic HDR Matching (Match Content)
By default, many Android TV boxes (including Mecool, Formuler, and Shield TV) set display output to Always HDR. This forces Standard Dynamic Range (SDR) live streams to display inside an artificial HDR container, making skin tones look unnaturally orange and colors washed out.
Step-by-Step Fix:
  1. Open Android TV Settings > Display & Sound > Display.
  2. Select HDR Settings (or Match Content).
  3. Change the setting from Always HDR to Match Content (or Auto).
  4. Result: Your TV will now remain in natural SDR mode for live channels and automatically switch into HDR10 / Dolby Vision mode only when an HDR stream is loaded.
2. Set the Optimal Color Space & Chroma Subsampling
To display accurate color palettes without color banding, your Android TV Box must match your TV panel's native HDMI color space.
Recommended Settings Breakdown:
  • For 4K HDR TVs: Select YCbCr 4:2:2 10-bit or YCbCr 4:2:0 10-bit at 60Hz.
  • For Standard 1080p HDTVs: Select YCbCr 4:4:4 8-bit or RGB Limited.
How to Apply:
  1. Go to Settings > Display & Sound > Advanced Display Settings.
  2. Select Custom Display Mode or Color Space.
  3. Choose YCbCr 4:2:2 10-bit for best compatibility across both SDR and HDR content.
3. Calibrate Video Hardware Renderers in Media Players
If video colors appear inverted or show a pink tint when playing 4K movies or VOD inside applications like TiviMate or OTT Navigator, the app's media player engine is failing to parse the stream's Color Primaries.
Setting Up Hardware Renderers:
  1. Open your player app's Playback Settings.
  2. Locate Video Decoder / Hardware Acceleration.
  3. Ensure video decoding is set to Hardware (HW) or HW+.
  4. If Dolby Vision files display a blank screen, locate Dolby Vision Compatibility Mode in player settings and set it to On (or convert DV to HDR10).
4. Enable HDMI Ultra HD Deep Color on Your TV Set
Even if your Android TV Box is correctly configured, your television's physical HDMI port must be unlocked to accept high-bandwidth 10-bit HDR signals.
Check Your TV Settings:
  • LG TVs: Go to Settings > Picture > Additional Settings > HDMI ULTRA HD Deep Color and turn it ON for your box's HDMI port.
  • Samsung TVs: Go to Settings > General > External Device Manager > Input Signal Plus and toggle it ON.
  • Sony TVs: Go to Settings > External Inputs > HDMI Signal Format and select Enhanced Format.
Q1: Why does my TV screen momentarily go black when starting a 4K movie?
A: This is a normal HDMI handshake process. The TV panel is dynamically switching its display resolution and refresh rate to match the movie's native HDR10 or Dolby Vision signal.
Q2: Does HDR consume more internet bandwidth?
A: No. HDR relates to color metadata and luminance levels embed in the video track. Stream bitrate is determined by resolution (1080p vs 4K) and video compression codecs (HEVC/AV1), not HDR color data itself.
Q3: What should I do if my TV does not support HDR?
A: Set your Android TV Box display output strictly to SDR. This forces the box to downsample HDR streams into clean SDR color profiles without washing out the image.
