How to Fix Video Micro-Stutter on Firestick: Enable Auto Frame Rate (AFR) Matching (2026 Guide)
If you notice subtle visual lag, motion judder, or micro-stuttering during fast-moving live sports broadcasts (like football or basketball) on your Amazon Fire TV Stick—even when your internet speed is extremely fast—the issue is almost certainly a frame rate mismatch.
Most TV displays operate at 60Hz by default, while international live streams are broadcast at varying native frame rates:
  • European Sports Streams: Broadcasted natively at 50 FPS (50Hz).
  • US Movies & VOD: Filmed at 24 FPS (23.976Hz).
  • US Live TV / News: Broadcasted at 60 FPS (59.94Hz).
When a Firestick forces a 50Hz European broadcast to display on a 60Hz screen setting, it causes a frame-pacing error known as telecine judder.
In this detailed technical guide, we show you how to enable Auto Frame Rate (AFR) Matching on Fire OS and inside top player applications like TiviMate to achieve buttery-smooth, broadcast-quality motion.
Motion Mismatch & Resolution Chart
Content Source Type Native Stream Frame Rate Default Firestick Output Display Result Without AFR Result With AFR Enabled
European Live Sports 50 FPS (50Hz) 60Hz forced Periodic stuttering every few seconds Smooth 50Hz native panel sync
US Movies / VOD 24 FPS (23.976Hz) 60Hz forced Motion judder during camera panning Authentic 24p cinematic motion
US Sports / News 60 FPS (59.94Hz) 60Hz forced Perfectly smooth Perfectly smooth
1. Enable Match Original Frame Rate in Fire OS System Settings
Amazon includes a built-in frame rate matching toggle inside Fire OS system settings, though it is turned off by default.
Step-by-Step Configuration:
  1. From your Firestick Home screen, open Settings (Gear Icon).
  2. Navigate to Display & Sounds > Display.
  3. Scroll down to Match Original Frame Rate and toggle it to ON.
  4. Set Resolution to Auto (Up to 4K Ultra HD) so the system can change refresh rates dynamically.
2. Configure Auto Frame Rate (AFR) Inside TiviMate
While enabling system-level AFR helps native apps, player applications require explicit frame rate matching permissions to switch your TV panel's refresh rate on the fly.
Setting Up AFR in TiviMate:
  1. Open TiviMate and go to Settings > Playback.
  2. Scroll down and locate Auto frame rate (AFR).
  3. Toggle Auto frame rate (AFR) to ON.
  4. Set AFR switch delay to 1 second (this gives your TV screen a brief moment to sync refresh rates without cutting off audio).
  5. Open a live 50Hz sports stream. Your TV will briefly blink or show a refresh rate pop-up (e.g., 1080p @ 50Hz), confirming that native frame rate matching is active.
3. Configure AFR in OTT Navigator & Other Players
If you use alternative players like OTT Navigator or XCIPTV, configuring media decoders ensures smooth motion rendering.
In OTT Navigator:
  1. Open Settings > Media Player.
  2. Select Auto Frame Rate (AFR).
  3. Choose System AFR or Software AFR Mode.
  4. Ensure your preferred video decoder is set to Hardware (HW+).
Advanced Troubleshooting: What to Do if Screen Goes Black
  • Brief Black Screen During Channel Switching: This is completely normal! It is called a "HDMI Handshake" as your TV switches hardware display frequencies from 60Hz to 50Hz or 24Hz.
  • Audio Desync After AFR Switch: If audio lags behind the video after matching frame rates, open your player settings and enable Pass-through Audio or adjust Audio Delay by -100ms.
Q1: Does Auto Frame Rate matching work on all TVs?
A: Most modern HDMI TVs support dynamic refresh rate switching between 24Hz, 50Hz, and 60Hz seamlessly. Older monitor displays fixed at 60Hz may not support 50Hz modes.
Q2: Why does 50Hz video stutter on a 60Hz setting?
A: Because 60 is not evenly divisible by 50, your Firestick must duplicate every 5th frame to fill the time gap, creating visible micro-stutters during horizontal camera motion.
Q3: Is AFR available on Fire TV Stick Lite?
A: Yes, Match Original Frame Rate is supported across all modern Firestick generations running Fire OS 6, 7, or 8.
Summary Checklist for Smooth Motion
  • Enable Match Original Frame Rate in Fire OS Display settings.
  • Enable Auto Frame Rate (AFR) inside your media player settings.
  • Set an AFR switch delay of 1 second to prevent HDMI handshake errors.
  • Use Hardware Video Acceleration (HW/HW+) alongside AFR.
