Onn 4K Pro vs. Fire TV Stick 4K: Best Budget Streaming Device in 2026?
For users looking to power their home streaming setup without breaking the bank, the sub-$50 price category offers some of the most competitive hardware on the market. Two top contenders dominate this space: Walmart’s Onn Google TV 4K Pro and Amazon’s Fire TV Stick 4K (2nd Gen).
While both streaming players deliver fluid 4K HDR playback and support modern video decoders, their hardware layouts, network connectivity options, and operating systems set them apart.
In this detailed comparison, we analyze both budget powerhouses across specs, app handling, storage capacity, and real-world performance.
Hardware Specs & Feature Comparison
Feature / Spec Walmart Onn Google TV 4K Pro Amazon Fire TV Stick 4K (2nd Gen)
Operating System Google TV (Android 12/14) Fire OS 8
Form Factor Tabletop Streaming Box / Hub Compact HDMI Dongle
RAM / Internal Storage 3GB RAM / 32GB Storage 2GB RAM / 8GB Storage
Wired Network Built-in 10/100 Ethernet Port Requires USB OTG Adapter
Wireless Connectivity Wi-Fi 6 (802.11ax) Wi-Fi 6 (802.11ax)
USB Expansion Built-in USB 3.0 Type-A Port Requires Micro-USB OTG Cable
Audio & Video Standards Dolby Vision, Dolby Atmos, AV1 Dolby Vision, HDR10+, Dolby Atmos, AV1
Key Differences Breakdown
1. Storage Capacity & EPG Performance
  • Onn 4K Pro: Equipped with 32GB of internal storage and 3GB of RAM. This expanded storage is a game-changer for media players like TiviMate or XCIPTV, enabling them to store massive TV schedules, channel logos, and video metadata without triggering "out of memory" errors.
  • Fire TV Stick 4K: Comes with 8GB of internal storage. While sufficient for basic app streaming, power users running multiple large playlists may need to clear app cache files periodically.
2. Built-in Ports & External Connectivity
  • Onn 4K Pro: Features a full USB 3.0 Type-A port and a dedicated Ethernet port right on the back of the device. You can plug in a USB flash drive for local recording or direct video playback without buying extra adapters.
  • Fire TV Stick 4K: Uses a traditional stick design that plugs directly into an HDMI port. Expanding storage or adding a wired network connection requires purchasing extra micro-USB splitters and OTG hubs.
3. User Interface & Ecosystem Freedom
  • Onn 4K Pro: Runs a clean, native Google TV interface. Sideloading third-party apps, file explorers, and backup utilities via the Downloader app is fast and straightforward.
  • Fire TV Stick 4K: Features Amazon’s content-focused Fire OS dashboard. While sideloading is fully supported, Amazon’s interface prioritizes sponsored content and requires navigation through Developer Options menus.
Q1: Does the Onn 4K Pro require a Walmart account to use?
A: No. The Onn 4K Pro runs standard Google TV and only requires a regular Google account to log in and download applications from the Play Store.
Q2: Can I record live TV broadcasts on the Onn 4K Pro using a USB drive?
A: Yes! Thanks to the built-in USB 3.0 port, you can plug in a USB flash drive or external SSD and set your media player app to save background recordings directly to the drive.
Q3: Which device handles 4K live streams better over Wi-Fi?
A: Both devices feature Wi-Fi 6 modules and deliver smooth 4K 60fps streams. However, if your router is far from your TV, the Onn 4K Pro’s built-in Ethernet port offers superior stability.
Q4: Can I install TiviMate on both devices?
A: Yes, TiviMate runs smoothly on both streaming devices.
Q5: Does the Onn 4K Pro remote have a "Find My Remote" feature?
A: Yes, the Onn 4K Pro box includes a button on the front of the unit. Pressing it causes the remote control to beep so you can locate it easily.
Verdict: Which One Should You Buy?
Choose the Onn Google TV 4K Pro if:
  • You want 32GB of internal storage and 3GB RAM for heavy media apps and EPG caching.
  • You need a built-in Ethernet port and a full USB 3.0 port for local storage expansion.
  • You prefer a clean Google TV user interface with hassle-free APK sideloading.
Choose the Fire TV Stick 4K if:
  • You prefer a hidden dongle form factor behind your wall-mounted TV.
  • You are already deeply invested in the Amazon Prime and Alexa smart home ecosystem.
  • You want high-quality 4K HDR playback in a traditional stick design.
